. None of the USB-C cables that I tested worked, only the USB-A -> RJ-45.
While it would have been easier to stay with the RJ-45 consoles, the reality is that technology moves on and there is limited space on the front of the 6300m's.
Original Message:
Sent: Mar 03, 2023 01:01 AM
Subject: Aruba 6300M & OOBM with USB to DB9 RS232 Adapter Hub help
@C0LdWir3
using a computer with USB is no issue here...
simply imagine in a remote location you have a 4 device 6300M stack and there is some issue and you can't access the OOBM....no techician onsite too....what do you do then?
With a console server you have the chance remotely access the console port of the switch and all it's units (if you connect all 4) ...there you can see and react....no matter if the switch's OS is loaded or the stack is working...you can simply fix it remote....
That's why i do not understand why aruba did move away from industrial standard RJ45 console connection to ONLY!! use USB...if it would have been my choice then i would moved away from aruba devices and bought other vendor just because of this shortsight design....
Original Message:
Sent: Mar 02, 2023 06:56 AM
I haven't actually tried any console server, but usual you use a USB data cables to connect to the CX switches and your operatiing system discovers the serial port that is actually inside the switch. You don't need a serial PC on the PC or any other RS-232 connection, afaik.
The RJ45 port would probably require RS-232 / Serial Port.
Did you set the speed correctly ?
This URL might have more usefull info:
https://www.arubanetworks.com/techdocs/AOS-CX/10.10/HTML/fundamentals_6300-6400/Content/Chp_IniCfg/con-con-por.htm
Let us know when you got it working.
Original Message:
Sent: Mar 01, 2023 02:19 AM
i just got the 6300M and updated to 10.9 firmware.
also got the " https://www.amazon.de/dp/B08NWPY8DQ/ref=pe_27091401_487024491_TE_item?th=1 " cable and connect it to my Digi Connect IT4, but it's NOT! working...the console server tells me connected, but no data is recieved....
![console](https://higherlogicdownload.s3.amazonaws.com/HPE/UploadedImages/zhLv4eDbS0Kttmhc26Uc_console-L.jpeg)
