Wired Intelligent Edge
Aruba 6300M / Split Detection
  • 1.  Aruba 6300M / Split Detection
    Posted May 06, 2020 08:40 AM
    Hi there
    My 6300m VSF Stack members are not in the same Building.
    I will configure the "Split Detection".
    Is it only possible to do this by MGMT RJ45 Port?
    Is it possible to configure this over a separate VLAN on the Access Switches / what are the steps for doing this?
    Thanks for your help.
  • 2.  RE: Aruba 6300M / Split Detection
    Posted May 06, 2020 08:50 AM
    I'm sorry --> its the wrong forum. How can I move this to:
    *Wired Intelligent Edge (Campus Switching and Routing)*
  • 3.  RE: Aruba 6300M / Split Detection
    MVP GURU
    Posted May 06, 2020 09:51 AM
  • 4.  RE: Aruba 6300M / Split Detection
    Posted May 06, 2020 11:19 AM
    Hi and Thanks a lot for your reply.
    I configured it on some 5400 Aruba Switches like this an it worked correctly.
    But now I try to make this on an 6300m  VSF Stack and I struggle with the configuration. When I refer to this guide, there is no command to do expect: "vsf split-detect mgmt-interface"
    https://techhub.hpe.com/eginfolib/Aruba/OS-CX_10.04/5200-6790/index.html#GUID-D8A2430B-C918-4FC6-AD8D-ECCBA07EA2D2.html
    But I can't find a guide how to configure the mgmt Ports for this.
  • 5.  RE: Aruba 6300M / Split Detection
  • 6.  RE: Aruba 6300M / Split Detection
    Posted May 06, 2020 11:36 AM
    Now it works. I hadto enter the command:  "vsf secondary-member 2"
    Before there was a master and a member --> now there is a master and a standby and now the split detection work when they are directly connected.
    Tomorrow I will try to do the split detection over a L2 VLAN on the Access switches because the 6300m are not in the same building.
    I will let you know if it works as expected
  • 7.  RE: Aruba 6300M / Split Detection
    Posted May 07, 2020 01:51 AM
    I've tested it now over a L2 VLAN on the access Switches and it works as expected.
    So the main thing was to set the second Switch in the stack as "vsf secondary-member 2".
    Kind regards
  • 8.  RE: Aruba 6300M / Split Detection
    Posted May 08, 2020 02:39 PM
    Greetings!
    In AOS-CX VSF stacks on the 6300 and 6200 switch families, split detection uses a connection between management ports on the primary and secondary members, and requires both to be connected to a common Layer 2 broadcast domain (not necessarily directly connected to each other or to a single common switch).
  • 9.  RE: Aruba 6300M / Split Detection
    Posted Apr 05, 2022 12:20 PM
    @DominikGy May I know what commands did you tried for this using VLAN on a access layer switch​
    Sahil Raina
