I created a certificate with our Certificate Authority and am receivin the following error when trying to upload the completed certificate to the Aruba OS:
Error Uploading Certificate: CertMgr error.
I've tried DER and P7B certs.
I've followed those procedures and still come up with the error :
I'm trying to generate a new CSR and new certificatenow to try.
You probally already found the solution, but I though I shared my solution in case anybody else runs into the same issue. We have an Internal CA (Server 2008 R2). I genererated a CA, but it is exported as a DER cert. Aruba seems to only like PEM certs. I used the site https://www.sslshopper.com/ssl-converter.html to convert the DER to a PEM cert. I was then allow to import the cert.
