aruba 68 Standalone
  • 1.  aruba 68 Standalone
    Posted Nov 05, 2014 09:49 AM
    I have aruba 68 and want to configure it to work as stand alone AP how I config the SSID ?
  • 2.  RE: aruba 68 Standalone
    Posted Nov 05, 2014 09:50 AM
    This is not possible. You need a controller.
  • 3.  RE: aruba 68 Standalone
    Posted Nov 05, 2014 09:51 AM
    is it must be ARUBA controller ? or i can manage it with other ?
  • 4.  RE: aruba 68 Standalone
    Posted Nov 05, 2014 09:52 AM
    Yes.
    The 68 is an old AP. Newer APs can be used in "standalone" mode if you order the Instant version.
  • 5.  RE: aruba 68 Standalone
    Posted Nov 06, 2014 02:17 AM
    HI
    isnt there any way to update the software or firmware so i can even just config the SSID ?
  • 6.  RE: aruba 68 Standalone
    Posted Nov 06, 2014 03:01 AM
    Unfortunately not.  You need the controller do do any setup on the AP68.
  • 7.  RE: aruba 68 Standalone
    Posted Nov 06, 2014 03:04 AM
    so is there avirtual controller even a trail to try it ?
  • 8.  RE: aruba 68 Standalone
    Posted Nov 06, 2014 03:09 AM
    no there's not.  As cappalli said, you'd be better of getting an Instant version of any other AP if you want to trial Aruba products.
    I would consider the AP68 to be legacy in any case.
  • 9.  RE: aruba 68 Standalone
    Posted Nov 12, 2014 05:31 AM
    Is there any option to upgrade the firmware so it could be configured?
  • 10.  RE: aruba 68 Standalone
    Posted Nov 12, 2014 05:54 AM
    to upgrade the firmare or configure, you still need the controller.
    There is no firmware for AP68 that will make it work without a controller like the IAPs.
