Aruba
  • 1.  Aruba
    Posted Nov 20, 2014 11:26 AM
    how to test WIPS in Aruba IAP
  • 2.  RE: Aruba
    Posted Nov 20, 2014 11:28 AM
    What are you trying to test? Very vague question.
  • 3.  RE: Aruba
    Posted Nov 20, 2014 11:34 AM
    I am trying to test how to block rogue AP and tried enabling hotspot on the laptop which is connected to IAP. but IAP does not block it.
  • 4.  RE: Aruba
    Posted Nov 21, 2014 12:43 AM
    please reply waiting for your sugestions.
  • 5.  RE: Aruba
    Posted Nov 24, 2014 02:46 PM
    You should be able to see the other network as Rogue/Interferring.  Containmnet is not on by default.  Depending on what version of code you are on you will need to bring up the IDS configuration.
