last person joined: 3 hours ago
Aruba 7005 , factory-defaulted and no link on no interfaces ? / preboot cli reset?
This thread has been viewed 80 times
  • 1.  Aruba 7005 , factory-defaulted and no link on no interfaces ? / preboot cli reset?
    Posted Jan 30, 2015 03:14 AM
    Hi
    wondering about some strange behaviour , not sure if the 7005 is faulty then i RMA it , the 7005 is our demo controller for customers and it's factory default , the CLI setup is working, but after the usual steps (country code, default IP , master , shutdown ports -> no ...) then controller is rebooting as usual and freezing on "reading default config", and nothing happens.
    surprisingly a webUI setup is not possible due to no ethernet link at all on no port, normally as usual its in switch-access mode vlan1 and you can access it on 172.16.0.254/24 as everyone knows.
    any ideas during boot-CLI to try some steps there, i never needed the boot-CLI to reflash/recover/etc   a controller.
    i expect that this MC is faulty on ethernet ports , besides this could be the reason that no eth is not working cause it's hanging on "reading default config" see screenshot below and so the webUI default web-wizard also not working .
  • 2.  RE: Aruba 7005 , factory-defaulted and no link on no interfaces ? / preboot cli reset?
    Posted Jan 30, 2015 03:19 AM
    Stop the controller before boot and run (here is a good how-to) and format the 0:2
    . Power cycle the controller and break into the CPBoot by hitting the enter key on startup (console access).
    => The one with cpboot> as the prompt - so the second one on a 7220.
    2. Format Partition 0:2, which is where the configuration file is stored:
    cpboot> format 0:2
    Format will erase everything on the internal flash's partition 2.
    Are you sure you want to continue (y/n)?y
    Formating.........
    Done
    Read more here:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Aruba-7220-stuck-reading-default-cfg/td-p/109911
  • 3.  RE: Aruba 7005 , factory-defaulted and no link on no interfaces ? / preboot cli reset?
    Posted Sep 15, 2017 09:38 PM
    We've just got a brand new Aruba 7005 controller and it seems to stuck in the boot process, just after "Starting OS services"
    Below is the output on the serial console. Are we missing something important or there is any problem with this unit?
    Stage 1 Loader 1.0.5.0 (build 56553)
    Built: 2016-09-22 at 05:05:37
    Secure Boot Enabled on the Processor
    Bank: Primary
    CPLD:  rev: 3.2 (0x10:000c)
    PRID: 000C1203
    POWER ON RESET CFG:C3C0FE2
    Initialized I2C0 Controller.
    Initialized I2C1 Controller.
    SPD Rev:0x11 DIMM:0 Type:2 Speed:666MHz #Rank:1
    DDR3: Node 0 Channel 0 Mem size = 4096 MB UDIMM
    set freq:666666
    DDR3: Node 0 DRAM frequency 666 MHz
    DDR3: Node 0 CPU frequency 500 MHz
    mtb_ps:125 clock:1500 trc:33 trcd:9 trp:9
    AP3:A0CFFF0 ODTP1:10000
    Board DDR VDD set to 1.35V.
    N:0 CH:0 additional rdlvl rdly:1
    N:0 Ch:0 m:32 s:32 R OK.
    Rank:0 HW WLVL Passed Mask:1FF
    n:0 ch:0 RTT WR:0200
    ===N:0 Ch:0 m:32 s:32 RW OK.
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF FF -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF 00 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:AA 55 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:00 00 -- PASS
    DDR3 Initialization Passed.
    NBU0 DRAM BAR0 base: 00000000 limit: 0013f000 xlate: 00000001 node: 00000000 (    0 MB ->   320 MB, size:   320 MB)
    NBU0 DRAM BAR1 base: 001d0000 limit: 00bff000 xlate: 00090001 node: 00000000 (  464 MB ->  3072 MB, size:  2608 MB)
    NBU0 DRAM BAR2 base: 00e00000 limit: 0128f000 xlate: 00290001 node: 00000000 ( 3584 MB ->  4752 MB, size:  1168 MB)
    Hit Ctrl + X keys to stop autoboot:  0
    CPBoot image is signed
    Verifying CPBoot checksum...
    CPBoot check passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ## Starting application at 0x8C100000 ...
    CPBoot 1.0.7.0 (build 56553)
    Built: 2016-09-22 at 04:52:55
    DRAM:  4 GB
    CPLD:  rev: 3.2 (0c)
    Flash: 16 MB
    PCIE (B0:D01:F0) : No Link.
    Pwr Mngr: 24
    Power: DC Adapter
    Bank:  Primary
    Board: A7005
    CPU:   XLP208 Rev B1 (Secure Boot)
    Clock: Core 500 MHz / SoC 500 MHz (0c3c0fe2)
    Reboot code: 0:0: 1: 8:40
    Proto :5
    Net:   ge-3, ge-2, ge-1, ge-0
    Inventory Verification: PASS
    Hit Ctrl + X key to stop autoboot:  0
    cpboot> bootf 0:1.
    USB0:   setting speed to USB_SPEED_HIGH
    2 USB Device(s) found
    #1 Storage Device(s) found
    ##Loading image 0:1###################
    Image is signed; verifying checksum...
    passed
    Signer Cert OK
    Policy Cert OK
      0:xlp_napi_vc_mask 0xf
      0:sae frequency is 250
      0:nlm_hal_set_sae_engine_sel: xlp2xx return
      0:-- SAE Frequency set to 250
      0:cde frequency is 333
      0:CDE Frequency set to 333MHz
      0:MSGRING_NAPI: Initializing NLM NAPI subsystem
    Aruba Networks
    ArubaOS Version 6.4.3.4 (build 51619 / label #51619)
    Built by p4build@formentera.arubanetworks.com on 2015-09-10 at 20:14:07 PDT (gcc version 4.4.5)
    Copyright (c) 2002-2015, Aruba Networks, Inc.
               <<<<<    Welcome to Aruba Networks - Aruba A7005    >>>>>
    Probing for EEPROM devices                            [ OK ]
    Probing for real-time clock                           [ OK ]
    Uncompressing core image files                        [ OK ]
    Extracting corefs                                     [ OK ]
    Enabling watchdog                                     [ OK ]
    Starting device manager                               [ OK ]
    Performing eUSB Flash fast test...                    [ DONE ]
        [ OK ]
    Mounting flash                                        [ OK ]
    Checking system inventory                             [ OK ]
    Installing ancillary FS                               [ OK ]
    Performing integrity check on ancillary partition 0   [ OK ]
    Reboot Cause: Power Cycle (Intent:cause:register ee:ee:0:c)
    Starting syslog service                               [ OK ]
    Restoring the database                                [ OK ]
    Generating SSH keys                                   [ OK ]
    Initializing TPM and certificates                     [ OK ]
    Checking for configuration upgrade                    [ OK ]
    Starting OS services                                  [ OK ]
  • 4.  RE: Aruba 7005 , factory-defaulted and no link on no interfaces ? / preboot cli reset?
    Posted Sep 15, 2017 10:37 PM
    You might want to call TAC.  You might have to RMA the controller.
