Comware
Aruba 7005: How to pick the right Firmware ? There are so many
  • 1.  Aruba 7005: How to pick the right Firmware ? There are so many
    Posted May 11, 2020 08:53 AM
    Hi, ive been tasked with troubleshooting a Wifi problem which occured recently;
    Root cause: An internal system error has occurred at file sapd_wlanconfig.c function sapd_wlanconfig_destroy line 51 error Error destroying VAP 0:0 created:1: No such device.
    After some research, it came up as an Bug, that can be fixed with an Firmware update.
    The question now relies on which one I should choose, since there are so many.
    My current firmware is 6.4.4.20, and this is the list of availiable software:
    Release 6.4.4.4-4.2.3.2
    Release 6.5.0.0-4.3.0.1
    Release 6.5.0.0-4.3.0.2
    Release 6.5.0.3-4.3.0.3
    Release 6.5.1.0-4.3.1.0
    Release 6.5.1.0-4.3.1.1
    Release 6.5.1.0-4.3.1.2
    Release 6.5.1.0-4.3.1.3
    Release 6.5.2.0
    Release 6.5.4.3
    Release 8.3.0.6
    Release 8.5.0.3
    Is the key to orient via the release notes and choose accordingly which features do I need and which not ? or is there an Indicator which releases are more stable than the other ?
    #firmware
    #bug
    #update
    #troubleshoot
    #release
  • 2.  RE: Aruba 7005: How to pick the right Firmware ? There are so many
    Posted May 11, 2020 11:21 AM
    I suggest you to re-ask here (Aruba Airheads Community), particularly start a (or search for a similiar) thread in the right section.
