Aruba 7005 reset button
This thread has been viewed 101 times
  • 1.  Aruba 7005 reset button
    Posted Jan 27, 2017 04:04 AM
    I forgot a login password of Aruba 7005.
    So I can't log in from broswer even though I only know the ip address and iopen log in window.
    Can you advice how can I rest the pssword?
    There is no reset button on the AP.
    Do I need to log in from console and reset password>?
    I don't have a console adaptor. Is it same as Cisco one?
    Regards
    SImon
  • 2.  RE: Aruba 7005 reset button
    Posted Jan 27, 2017 04:14 AM
    You can use a mini-USB cable for console access. To connect it to your computer and allow it to show up as a com port, You will need to download the driver mentioned in the installation guide here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14426
    When you connect the cable and it shows up as a com port on your computer use putty or any other terminal program to select it.
    You will then need to execute the password restore procedure here: http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/Aruba-Controller-Password-Reset-Jan-2014/ta-p/143373
  • 3.  RE: Aruba 7005 reset button
    Posted Jan 29, 2017 10:05 PM
    Thanks a lot!
