hey there...
i installed a 7005 controller and 5 AP-115 with 3 WLANs. WLANs are working and I can connect but i dont have connectivity (cant access default gateway).
- Each WLAN is mapped to a VLAN and the controller itself has his IP in another VLAN-Interface.
- Each VLAN is mapped to a Port as ACCESS PORT
When i have connected the Port with the VLAN where the controller has its IP, I can access the Controller, the APs find the Controller and the WLANs come up(but clients can not access their default gateway), BUT when i connect the next cable (which goes to the same swith but to another VLAN ACCESS PORT) the APs disconnect ant i can not access the controller, since i disconnect the cable.
What am i missing? I just need to connect the WLAN-VLANs to the infrastrukture where the VLANs already exist and are working.
the Switch shows all port up and running and SPANNING TREE Forwarding a VLAN per Port, also no Error-disable or port security...
#7005
