Aruba 7010 Firmware up-gradation
This thread has been viewed 26 times
  • 1.  Aruba 7010 Firmware up-gradation
    Posted Mar 06, 2018 11:05 AM
    Recently we have purchased Aruba 7010 controller.
    current software version is 6.5.1.4 we are planning to upgrade the version to latest.
    purchased licenses and controller are registered on HPE My networking portal.
    which is the latest software version for controller and from where will get the firmware image.
  • 2.  RE: Aruba 7010 Firmware up-gradation
    MVP EXPERT
    Posted Mar 06, 2018 11:48 AM
    If you have a valid support contract you can download the files from the Aruba Support site. With ArubaOS 6.5.4.x being the latest available firmware (unless you have a requirement for ArubaOS 8.2.0.x).
    http://support.arubanetworks.com/
  • 3.  RE: Aruba 7010 Firmware up-gradation
    Posted Mar 07, 2018 01:23 AM
    hi zalion0, thanks for the response.
    we are purchased the product on last month with couple of AP & PEF license.
    what is the major difference between ArubaOS 6.5.4.x & ArubaOS 8.2.0.x, and is there any configuration difference on 8.2.0.x as compared to 6.5.4.x.
    so to download firmware files we need to create (register) a account on http://support.arubanetworks.com, am i correct?, for getting the license key (AP & PEF) we have register (create the aaccount) the same on HPE my networking portal.
  • 4.  RE: Aruba 7010 Firmware up-gradation
    MVP EXPERT
    Posted Mar 07, 2018 03:37 AM
    Hey, take a look at the below slides, this gives a good over view of the current features between AOS 6 and AOS8.
    https://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/64825/1/Aruba%20Mobile%20First%20Platform%20-%20Introduction%20to%20ArubaOS%208.pdf
    That is correct, you should've been set up with a Partner ID by the reseller that you purchased the controller from. This would also be the case to obtain the license files as well.
  • 5.  RE: Aruba 7010 Firmware up-gradation
    Posted Mar 07, 2018 03:44 AM
    hi zalion0, Thanks for the more details about version /.
    actually we sold the 7010 controller to our customer and to get the license key we have created a account on HPE my networking portal with customer details (email id, customer name, adress, etc).
    can we able to download the software image from the same acount.
