Aruba 7010 voltage input
  • 1.  Aruba 7010 voltage input
    Posted Jul 17, 2018 02:35 PM
    I can't find any specifics on this by checking data sheets, but maybe my search powers are struggling today.  I'm planning on building out an office space with 2x Aruba 7010 controllers, but the PDU's we are bringing in are 220v rated.  The exact model appears to be a JW681A.
    Can anyone help me determine if this support higher voltages, or if I need a step down transformer to not fry these controllers out?
  • 2.  RE: Aruba 7010 voltage input
    Posted Jul 17, 2018 11:53 PM
    All AC powered controllers have a universal voltage PSU - please see below excerpt from the hardware install guide.
    (https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=26041)
    7010 Specifications
    Physical
     Device Dimensions (without mounting brackets) (HxWxD): 1.74” x 12.75” x 13.0” (4.42 cm x 31.75 cm x33.0 cm)
     Device Weight: 7.4 lbs (3.4 kg)
    Power Supply Specifications
     225W AC Power Supply
     AC Input Voltage: 100 VAC to 240 VAC <<<<<
     AC Input Current: 3.5 A max.
     AC Input Frequency: 50 to 60 Hz
    Operating Specifications
     Operating Temperature Range: 0 °C to 40 °C (32 °F to 104 °F)
     Operating Humidity Range: 5% to 95% (RH), non-condensing
    Storage Specifications
     Storage Temperature Range: 0 °C to 50 °C (32 °F to 122 °F)
     Storage Humidity Range: 5% to 95% (RH), non-condensing
