Aruba 7030 and hotel local network
This thread has been viewed 38 times
  • 1.  Aruba 7030 and hotel local network
    Posted Mar 10, 2021 10:46 AM
    Good afternoon, please help me figure out where to enable speed limiting for the guest wifi network. A network was built in the hotel of 65 AP303 connected to two 7030. The problem is that when several guests start downloading something, they occupy the entire channel and the rest of the guests simply cannot connect normally or they slow down. Unfortunately, I did not find any instructions in Russian, I really hope for your help. The old administrator quit and there is no way to contact him. I apologize for the translation by google translator.
    Sergey
  • 2.  RE: Aruba 7030 and hotel local network
    Posted Mar 11, 2021 09:44 AM
    You can throttle guest user role bandwidth.
    Configuration > Roles & Policies > Roles
    Select existing guest user role
    Show Advanced View > Bandwidth Tab > Total Limit for This Role
    Select Per User and Configure the value
    If you need Application-level bandwidth  make sure DPI is enabled
    Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
    Network Engineer
    Plexus Global (Pvt) Ltd
    Colombo Sri Lanka
    +94717327420
  • 3.  RE: Aruba 7030 and hotel local network
    Posted Mar 12, 2021 12:32 PM
    Thank you so much, I had to update the firmware for this role to appear, but in the end everything worked
    Sergey Baz
  • 4.  RE: Aruba 7030 and hotel local network
    Posted Mar 12, 2021 03:32 AM
    Hello Sergey! You can do rate limit per role on this screen. You can contact local account manager or partner for proper consultaion in Russian
  • 5.  RE: Aruba 7030 and hotel local network
    Posted Mar 12, 2021 12:33 PM
    Thank you very much, do you accidentally know the contacts of Russian managers?
    Sergey Baz
