Aruba 7030 controller guest network setup
  • 1.  Aruba 7030 controller guest network setup
    Posted Oct 29, 2020 09:08 AM
    I have an aruba 7030 controller maning 10 access points. i have tried to create a guest wifi but it is not broadcasting. i need some help on how to setup this guest wifi on 7030 controller. Thank you.
    MJustus
  • 2.  RE: Aruba 7030 controller guest network setup
    MVP EXPERT
    Posted Oct 29, 2020 10:28 AM
    There is numerous reasons as to why this could be, what does your configuration look like? Are you certain the APs are broadcasting any SSIDs? What is the output of the following
    show ap bss-table
    show profile-errors
    Craig Syme
