aruba 7030 VRRP setup
  • 1.  aruba 7030 VRRP setup
    Posted Sep 21, 2016 10:48 AM
    On a 7030 controller I setup 5 vlan, one for managment to connect the other controller and ap. To setup a VRRP redudancy I have to setup all the vlan on the other controller or I must setup only the managment vlan and the configurations are replicate from master ?
    Thanks for all.
  • 2.  RE: aruba 7030 VRRP setup
    Posted Sep 21, 2016 11:04 AM
    At a minimum, you need to setup the managmeent VLAN on the 2nd controller and give it an IP.   The redundancy piece (VRRP) needs to be setup manually on each controller; redundancy information when it comes to VRRP does not sync between master and locals (see below).
    Depending on your VLAN setup; you may need to add the other 4 VLANs as well if you want clients to use them if you are using this controller for failover.
    Have a look at the following for configuration information:
    http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/VRRP/Redundancy_Parameters.htm
  • 3.  RE: aruba 7030 VRRP setup
    Posted Sep 21, 2016 03:13 PM
    Yes I need all the vlans for the clients. So also to secondary controller I need I ip for any vlan interface. It's right?
    The tracking on vlan or interface is critical or I can choose if I need?
