Aruba 7200 controller USB access
This thread has been viewed 23 times
  • 1.  Aruba 7200 controller USB access
    Posted Oct 25, 2013 03:52 AM
    is there a way to use the USB port on a 7240 controller from cpboot> promt to upload a firmware to the boot flash?
    I tried some USB drives, but always received a message like "filesystem needs to be ext2/3 or vfat". Are there any specifications on the USB drives to be used?
    Thanks and best regards
    #7240
  • 2.  RE: Aruba 7200 controller USB access
    Posted Oct 25, 2013 06:02 AM
    I just found the answer myself::catvery-happy:
    To use USB on a 7200 controller, format the usb drive i.e. in vfat format, then copy the firmware image on it.
    When the controller is then in cpboot> prompt, you can load the image from external USB via
    cpboot> bootf 1:1 arubaos_72xx_6.2.1.4_40075
    I somehow could not find which usb partition referred to the external usb drive. As it seems USB0 is the internal flash and USB1 is the external. Maybe someone can confirm this.
    Thanks/Cheers
  • 3.  RE: Aruba 7200 controller USB access
    Posted Feb 20, 2017 03:30 PM
    the two internal partitions are recognized as 0:0 bein the primary slot and 0:1 being the secondary slot.  The two external usb ports are recognized as 1:0 and 1:1.
