Network Management
Aruba 7205 Controller FW upgrade
This thread has been viewed 16 times
  • 1.  Aruba 7205 Controller FW upgrade
    Posted Dec 20, 2019 02:51 PM
    Hi Aruba newbie here,
    I just unboxed a 7205 Controller and am running into issues trying to update the firmware of the device. Currently the controller is on ArubaOS 6.5.4.8 and 8.6 is the most recent release. I have tried updating the controller via the CLI and when I attempt to update I get a response that "command is not supported on this platform"
    CE-ARUBA-01)#copy usb: standard-mibs_8.6.0.0_73144.tar.gz system: partition 0
    I also attempted from the web GUI and I cannot locate the aruba.sha256 download for 8.6 or any 8.x version.
    On another note, am I downloading the correct file (tar.gz) I tried to download the .iso but I my account is not "entitled" so those are blanked out. If that is the issue I'm facing and I'm trying to use the wrong file, how do I make my account entitled?
    Any ideas, tips? appreciate it!
    CE-ARUBA-01) #show image ver
    Partition : 0:0 (/dev/usb/flash1) **Default boot**
    Software Version : ArubaOS 6.5.4.8 (Digitally Signed SHA1/SHA256 - Production Build)
    Build number : 65873
    Label : 65873
    Built on : Fri Jul 20 07:50:02 UTC 2018
    Partition : 0:1 (/dev/usb/flash2)
    Label : 65873
  • 2.  RE: Aruba 7205 Controller FW upgrade
    Posted Dec 20, 2019 03:39 PM
    You are using the wrong file.  The file you should use to upgrade the 7200 series controller is in the screenshot below.
