ARUBA 7210 and 7220 HA
  • 1.  ARUBA 7210 and 7220 HA
    Posted Jun 02, 2018 06:33 PM
    Hi all i have an issue regarding HA.
    we have 2 controllers, 7210 and 7220, 7210 is master and 7220 is local. The issue is that both controllers are synching database each other but when master goes down, APs do not shift to local controller. Local controller is able to ping any UP AP.  Need help.. its urgent.
  • 2.  RE: ARUBA 7210 and 7220 HA
    Posted Jun 02, 2018 10:06 PM
    Can you post:
    from Master: show switches, show license, show ap database, show license server-table
    from local: show license, show ap database
  • 3.  RE: ARUBA 7210 and 7220 HA
    Posted Jun 19, 2018 02:17 AM
    컨트롤러의 HA 구성시 필요한 설정을 모두 하였나요?
    lms-backup lms 설정 이 되어 있어야 하며 ap-system profile 에 적용이 되어 있어야 합니다.
    추가로 라이선스 상태 (centralizied licensing enable 설정 ) 확인이 필요합니다.
  • 4.  RE: ARUBA 7210 and 7220 HA
    Posted Jun 19, 2018 02:20 AM
    Once the flag information in the AP database information is displayed as S?
    If it is not marked as S, it is not a normal HA configuration state.
    Did you check preemption when configuring HA?
