Aruba 7210 controller port-channel
  • 1.  Aruba 7210 controller port-channel
    Posted Jul 19, 2017 08:01 AM
    Hello Airheads,
    do you know f you can bundle all 6 ports on a 7210 controller into a 6 port etherchannel.
    Thereby making a 6 Gigabit etherchannel (port-channel)
    cheers
    pete
  • 2.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 08:09 AM
    Maybe.  You can have up to 8 member ports in a port-channel, but they all must be the same speed.  So if you're running the four SFP+ ports at 10Gb, then you could only have those 4 ports in the port-channel.
  • 3.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 08:56 AM
    thank you for your reply.
    we are planning to run all 6 ports @ the same speed yes.
    So that would mean the four SFP's running @ 1 gigabit and the
    two dual personality ports at 1 gigabit.
    hopefully that would be ok?
    pete
  • 4.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 10:40 AM
    Yes, you should be fine with that configuration. JJ
    #AirheadsMobile
  • 5.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 10:48 AM
    hello JJ,
    I Have managed to get a 7210 controller and tried to add the 10 gigabit
    ports into a port channel that i already had added the 1 gigabit ports to and i get an error message saying "member 0/0/2 speed doesn't match Pc-1 speed".
  • 6.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 11:28 AM
    hello again,
    i am beginning to think it's not an option to have the 2 x 1gigabit ports and the 4 x 10gigabit SFP ports in the same port channel.
    Thanks for having a look though appreciate you taking the time JJ.
    CHEERS
    PETE
  • 7.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 12:00 PM
    @pete_elms wrote:
    hello again,
    CHEERS
    PETE
    The media in a port channel must be the same..
  • 8.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 11:56 AM
    Hi Pete, What if you set the speed on the SFP+ ports to 1Gbps first? then try to add to the port-channel? Best, JJ
    #AirheadsMobile
  • 9.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 12:01 PM
    #AirheadsMobile
    You cannot, unfortunately.
  • 10.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 12:02 PM
    Thanks for the confirmation, Colin!
    #AirheadsMobile
  • 11.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 12:08 PM
    Colin and JJ,
    What if i was to purchase 1Gigabit SFP's making it a total of 6 x SFP's
    would i then be able to have a 6 x port port-channel?
    cheers
    pete
  • 12.  RE: Aruba 7210 controller port-channel
    Posted Jul 19, 2017 12:55 PM
    I am not sure.  The big question is, why do you need six physical interfaces?  The back of the napkin calculation is 100 APs for each gigabit interface...
