Aruba 7210 Master Stand-alone Controller help
  • 1.  Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 07:51 PM
    I was able to procure an Aruba 7210 and AP-335 for my home lab and was wondering if anyone could help or point me in the direction of configuring the 7210 as the master stand-alone . I have a Juniper EX-4200-48PX Switch so I do have a way to power the access point. Any help is greatly apprecaited and have done some research on configuring my setup but have only come accross vides/documents on configuring the 7210 as the master controller with 7000 series switches as the local controllers. Currently only have the once access point and my add a couple more as time progresses but not anytime soon.
  • 2.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 08:27 PM
    What version of ArubaOS?
  • 3.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 08:48 PM
    The Controller is 8.0.0.0 (build 55647) another question i have how do i go about upgrading that to the latest ArubaOS?
    I appreciate the quick replay and any help you can provide.
  • 4.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 09:54 PM
    The 7210 does not come with ArubaOS 8.0 by default.  Where did you download it from?  You typically need a support contract to download the latest ArubaOS...
  • 5.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 10:06 PM
    I didnt download it that is what the controller came with.
  • 6.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 12, 2018 10:23 PM
    Any controller that comes from HPE would not have 8.x on it.  With that being said, if you got it from a distributor, the distributor could have loaded it on your controller and you probably would have to contact them to find out how you should upgrade.  We are up to 8.2.x right now, and running 8.0 is not recommended...
  • 7.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 12:29 PM
    Ok i have the updated os 8.2.1.0
  • 8.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 12:36 PM
    Is there more than one controller in your lab? What master controller is the 7210 going to be a local for?
  • 9.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 12:53 PM
    Currently all I have is the 7210 controller and the AP-335 I do not have a 7000 series controller and want to get this small setup working with what I currently have.
  • 10.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 01:30 PM
    Cool. For correct terminology then, the 7210 will be set up as a master or standalone controller. Local implies that there's a master controller available to push config to it. The startup wizard via the CLI will ask if the controller is a local or master, that's why the distinction is important.
  • 11.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 01:23 PM
    I also purchased the license for the 1 access point (JW471AAE).
  • 12.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 01:32 PM
    Were any other licenses purchased, or just the AP license?
  • 13.  RE: Aruba 7210 Master Stand-alone Controller help
    Posted Apr 13, 2018 01:38 PM
    License wise not that I am aware of will I require more than that to get this setup working correctly? I apologize for sounding so ignorant in all this setting up my own home lab to learn and tinker with.
    I appreciate the clarification on the terminology I guess in all my research that was confusing me.
