aruba 7240xm power and staus led is amber
  • 1.  aruba 7240xm power and staus led is amber
    Posted Jul 02, 2019 11:02 PM
    aruba AC 7240xm power and status led is amber solid,AC is running normally。Does AC is trouble ? The green color shown in the 7200 installation  guide is normal。Does I need  to open a case?
    thanks !
  • 2.  RE: aruba 7240xm power and staus led is amber
    Posted Jul 02, 2019 11:14 PM
    AC led picture
  • 3.  RE: aruba 7240xm power and staus led is amber
    Posted Jul 02, 2019 11:41 PM
  • 4.  RE: aruba 7240xm power and staus led is amber
    Posted Jul 03, 2019 10:37 PM
    thanks,I will open a case。
    show inventory
    Supervisor Card slot            : 0
    System Serial#                  :
    CPU Card Serial#                :
    CPU Card Assembly#              : 2010219H
    CPU Card Revision               : (Rev:07.00)
    Interface Card Serial#          : AI49050387 (Date:12/10/18)
    Interface Card Assembly#        : 2010085E
    Interface Card Revision         : (Rev:04.00)
    SC Model#                       : Aruba7240XM
    HW MAC Addr                     : 00:1a:1e:05:85:18 to 00:1a:1e:05:85:1f
    CPLD Version                    : (Rev: 3.0)
    Power Supply 0                  : Present               : Yes (Not Functional)
                                    : 12V OK                : No
                                    : Fan OK                : No
                                    : Aruba Model No        : 2510057
                                    : Vendor & Model No     : QCS DCJ3501-01P
                                    : Serial No             : QCS180620AH
                                    : MFG Date              : 2/7/18
                                    : Output 1 Config       : 12V 350W
                                    : Input Min             : 90V AC
                                    : Input Max             : 264V AC
    Power Supply 1       : Present               : Yes
                                    : 12V OK                : Yes
                                    : Fan OK                : Yes
                                    : Serial No             : QCS183921DH
                                    : MFG Date              : 9/28/18
    Main Board Temperatures         :
                                    : U24 - Local Temp      35 C (shadow of XLP heatsink)
                                    : Q1  - Remote 1 Temp   38 C (shadow of VRM, VDD_CPU)
                                    : Q2  - Remote 2 Temp   36 C (shadow of VRM, VDD_SOC)
                                    : U44 - Local Temp      27 C (shadow of DPI connector)
                                    : U29  - Remote 1 Temp  40 C (XLP die temperature)
                                    : Q36  - Remote 2 Temp  30 C (shadow of 98X1422)
                                    : J2  - DDR A Temp      27 C (DDR3 A temp)
                                    : J4  - DDR B Temp      28 C (DDR3 B temp)
                                    : J1  - DDR C Temp      27 C (DDR3 C temp)
                                    : J3  - DDR D Temp      28 C (DDR3 D temp)
                                    : Port 0 Temp           148 C (1G PHY temp)
                                    : Port 1 Temp           148 C (1G PHY temp)
    Interface Board Temperatures    :
                                    : U21 - Local Temp      28 C (shadow of port 1 RJ45)
                                    : Q4 - Remote 1 Temp    28 C (shadow of 88E1543)
                                    : Q3 - Remote 2 Temp    34 C (shadow of 88X2140)
    Fan  0                          : 9060 rpm (5.450 V),Speed Low
    Fan  1                          : 8936 rpm (5.405 V),Speed Low
    Fan  2                          : 8957 rpm (5.495 V),Speed Low
    Fan  3                          : 8926 rpm (5.450 V),Speed Low
    Main Board Voltages             :
    ispPAC_POWR1014A_A              :
                                    : 1V2                  1.20V sense 1.230 V
                                    : VDD SOC              1.050V sense 1.048 V
                                    : VCC IOBD 1V5         1.50V sense 1.524 V
                                    : DDR3BD_VTT           0.75V sense 0.748 V
                                    : VCC 1A               1.00V sense 1.022 V
                                    : IV8_DIGITAL          1.80V sense 1.858 V
                                    : 3V3_MAIN             3.30V sense 3.342 V
                                    : VCC1                 1.00V sense 1.018 V
                                    : VCC25                2.50V sense 2.520 V
                                    : 3V3 SB               3.30V sense 3.342 V
    ispPAC_POWR1014A_B              :
                                    : VDD                  1.100V sense 1.100 V
                                    : VCC IOAC 1V5         1.50V sense 1.524 V
                                    : DDR3AC_VTT           0.75V sense 0.754 V
                                    : VDD_SRAM             1.00V sense 1.044 V
                                    : VCC1B                1.00V sense 1.026 V
                                    : 1V8_ANALOG           1.80V sense 1.836 V
                                    : 1V8                  1.80V sense 1.844 V
                                    : VDDIO12_XAUI         1.20V sense 1.224 V
                                    : 5V                   5.00V sense 4.986 V
    Interface Board Voltages        :
    ispPAC_POWR6AT6                 :
                                    : VCC33                3.30V sense 3.378 V
                                    : VCC 18               1.80V sense 1.858 V
                                    : VCC1                 1.00V sense 1.030 V
                                    : VCC12                1.20V sense 1.220 V
                                    : VCC12-DVDD           1.20V sense 1.208 V
                                    : VCC9                 0.90V sense 0.928 V
  • 5.  RE: aruba 7240xm power and staus led is amber
    Posted Jul 04, 2019 01:45 AM
    you appear to have a PSU 0 fault - "not functional"
                                    : 12V OK                : No
                                    : Fan OK                : No
                                    : MFG Date              : 2/7/18
  • 6.  RE: aruba 7240xm power and staus led is amber
    Posted Jul 04, 2019 05:22 AM
    yes,I figured it out...
    It display amber that only one power module is used。when two power module is used ,it dispaly green...
    thanks !
