Aruba 8.3 - Uploading custom HTML captive portal
This thread has been viewed 37 times
  • 1.  Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 15, 2019 05:30 AM
    We recently been deploying custom guest captive portal on our Aruba controllers. All is straightforward on the controllers running 6.x and working as expected.
    Then we had one controller pair which is running 8.3.... Besides the fact that I'm missing the upload "content" option, I'm not able to get it working on this controller. I pretty much used the same config as the 6.x controllers, but I've also tried just step-by-step setting up a new captive portal and uploading just the .html login page.
    The issue is that the guest will get connected, it will end up in the preauth role, the captive portal will pop up but I'm getting a HTTP 404 Not Found. Connectivity wise it's all ok, because I can ping my gateway, I can also ping the guest IP on the controller, but it's giving me a 404. To me it seems that the custom HTML code is not getting uploaded correctly, or there's something wrong with the path (/upload/custom/<cp-profile>/).
    Has anyone else have experience with uploading custom HTML pages to controllers running version 8.3?
  • 2.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 15, 2019 08:01 AM
    hmm so I just stumbled across this logging:
    Mar 14 19:32:30 nginx: 1552591950.197009 [error] 6208#0: *14550 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
    Mar 14 19:33:41 nginx: 1552592021.201440 [error] 6208#0: *14622 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
    Mar 14 19:36:02 nginx: 1552592162.299281 [error] 6208#0: *14760 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
    Mar 15 08:44:52 nginx: 1552639492.535908 [error] 6208#0: *14894 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
    Mar 15 08:45:29 nginx: 1552639529.156860 [error] 6208#0: *14928 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
    Mar 15 08:54:45 nginx: 1552640085.516166 [error] 6208#0: *15597 open() "/flash/upload/custom/Internal_CP/login.html" failed (2: No such file or directory), client: 192.168.20.77, server: localhost, request: "GET /upload/custom/Internal_CP/login.html?<output stripped on purpose>
  • 3.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 15, 2019 08:16 AM
    I see this in the logging. Is there some kind of DIR command to see if the files are actually getting uploaded correctly.
  • 4.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 15, 2019 09:11 AM
    I am not aware of a way to see the directory listing.
    You can try https://<ip address of controller>/upload/custom/Internal_CP/login.htm.
  • 5.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 15, 2019 11:46 AM
    Hi Cjoseph,
    we noticed that the controller was rejecting the HTML upload, because it's seeing the ";" semicolon character as a SQL injection attack.
    Mar 15 14:34:46  httpd[29464]: Found SQL injection character ;         src: url(futura.woff) format('woff');         unicode-range: U+0000-00FF, U+0131, U+0152-0153, U+02BB-02BC, U+02C6, U+02DA, U+02DC, U+2000-206F, U+2074, U+20AC, U+2122, U+2191, U+2193, U+2212, U+2215, U+FEFF, U+FFFD;     }     .UAP {         color: #666 !important; ^I^Imargin-left: auto; ^I^Imargin-right: auto; ^I^Ipadding-inline-start: 15px; ^I^Ipadding-left: 15px; ^I^Ipadding-right: 15px;     }     .title {         font-size: 25px;
    Mar 15 14:34:46 httpd[29464]: arci_cgi: Returning error as the input arguments might have their values altered. Could be SQL Injection. M
    when we upload a simple html file without semi-colons, it works. But we need the semi-colons for the css and script to work properly. So we're awaiting TAC response, they are going to try and reproduce in the lab
  • 6.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 18, 2019 05:25 PM
    TAC was able to reproduce the issue in their lab, standalone controller running version 8.3.0.4.
    The OS sees the ";" character as a SQL injection, so it won't take any HTML page or content which has that character.
    Suggested we upgrade to 8.3.0.6, as this fix the issue in their lab.
  • 7.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 20, 2019 11:08 AM
    We're still missing the upload content option.
    Did you find it or did you find any way to upload images and css files ?
    thanks
  • 8.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Mar 21, 2019 02:28 AM
    correct, I added this as a follow up. There is no clear "Content" upload input box anymore, but there is a workaround ;)
    - upload the css and other content files via the "Welcome page" upload box. This will just upload the files into the flash/upload/customs folder, and it will work.
  • 9.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Jan 19, 2021 10:32 AM
    Is this still the correct directory to upload files that will be used for custom captive portal, flash/upload/customs? I tried calling my background image files in my html code and it would not load it.  Thanks for your response in advance.
    Miguel Balagot
  • 10.  RE: Aruba 8.3 - Uploading custom HTML captive portal
    Posted Jan 20, 2021 04:56 AM
    This should work:
    From UI- Navigate to Configuration-Role & Policies
    Select the Role. Select Advanced, Click on Captive Portal.
    Select Internal Captive Portal - Custom HTML.
    Upload all the images and files and then lastly the page which is to be presented.
    Note that you probably should host your captive portal externally, not on the controller as it is not designed to be a web-server. In small deployments where you can't host the portal externally, by exception you could use the Custom HTML.
    If you get stuck, it may make sense to work with Aruba support as not so many people use this feature for the reason just mentioned.
