Wired Intelligent Edge
Aruba 8320 DNS 8.8.8.8
This thread has been viewed 46 times
  • 1.  Aruba 8320 DNS 8.8.8.8
    Posted Mar 23, 2021 08:53 AM
    Hi
    I see our 8320s sourcing DNS to 8.8.8.8 but cannot find this in the config of the switch. Assume this is some kind of factory default. How can it be disabled?
    Cheers
    Timo Krjukoff
    Timo Krjukoff
  • 2.  RE: Aruba 8320 DNS 8.8.8.8
    MVP GURU
    Posted Mar 23, 2021 11:24 AM
    Hi @tkrjukoff, DNS at 8.8.8.8 (Google DNS) is not factory default at all.
    You could check by watching at the output of show ip dns CLI command on your Aruba 8320.
    Are you sure there is no line like (example) ip dns server-address <IP-of-DNS-Server> vrf mgmt (or vrf default) on your running configuration?​
    Which version of ArubaOS-CX is your Aruba 8320 running on?
    Davide Poletto
  • 3.  RE: Aruba 8320 DNS 8.8.8.8
    Posted Mar 24, 2021 01:21 AM
    Hi @parnassus
    show ip dns gives a blank output, no dns configured in any of the VRFs.
    SW version: 10.05.0020. The switches burst 8 U/DNS packets every 5 minutes.
    /etc/resolv.conf has nothing either.
    A bit puzzled here???
    Cheers
    /timo​
    Timo Krjukoff
  • 4.  RE: Aruba 8320 DNS 8.8.8.8
    Posted Mar 24, 2021 05:14 AM
    Would you please share the output of
    show aruba-central
    Vincent Giles
  • 5.  RE: Aruba 8320 DNS 8.8.8.8
    Posted Mar 24, 2021 05:40 AM
    Hi @vincent.giles
    XXXX# show aruba-central
    Central admin state : enabled
    Central location : N/A
    VRF for connection : N/A
    Central connection status : N/A
    Central source : dhcp
    Central source connection status : connection_failure
    Central source last connected on : N/A
    System time synchronized from Activate : False
    Activate Server URL : devices-v2.arubanetworks.com
    CLI location : N/A
    CLI VRF : N/A
    Cheers
    /timo​
    Timo Krjukoff
  • 6.  RE: Aruba 8320 DNS 8.8.8.8
    Posted Mar 25, 2021 04:23 AM
    Please disable central and check that you no longer have these dns queries triggered by the switch:
    8320(config)# aruba-central
    8320(config-aruba-central)# disable
    Vincent
    Vincent Giles
  • 7.  RE: Aruba 8320 DNS 8.8.8.8
    Posted May 26, 2021 07:05 PM
    Hi @Parnassus
    Would you like to help me . How we can create DHCP Pool and ip dhcp excluded address on HP Aruba 8320 switch. I didn't configure dhcp on core switch but it show active .
    Adnan Khan
  • 8.  RE: Aruba 8320 DNS 8.8.8.8
    MVP GURU
    Posted May 27, 2021 03:10 AM
    Dear Adnan Khan, this is the wrong thread to develop your topic (you're OT). Please open a NEW thread and explain there what is your issue/request.
    Davide Poletto
