Higher Education
last person joined: 25 days ago
Got questions on how to enable mobility in education? Submit them here!
Aruba 8320 does not support login from switch to Clearpass for RADIUS authorization?
  • 1.  Aruba 8320 does not support login from switch to Clearpass for RADIUS authorization?
    Posted Mar 12, 2024 02:27 PM
    I am attempting to harden our 8320s used as core switches to require domain login instead of local switch admin login. I have a fleet of 6200F used as edge switches and this works flawlessly using:
    switch(config)# radius-server host clearpass.*.* key plaintext secretkey clearpass-username user clearpass-password plaintext password
    When I attempt the same on the 8320 switch I get:
    Invalid input: clearpass-username
    Does the 8320 not support this feature although the 6200F does?
    Thank you for taking the time to read. If anyone has any ideas that would be great.
  • 2.  RE: Aruba 8320 does not support login from switch to Clearpass for RADIUS authorization?
    Posted Mar 12, 2024 03:01 PM
    If you are just using RADIUS for system login, you do not need the "clearpass-username" and "clearpass-password" attributes. Those are for the downloadable user roles function.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Aruba 8320 does not support login from switch to Clearpass for RADIUS authorization?
    Posted Mar 13, 2024 04:21 PM
    That is exactly what I needed to know. Knowing I was barking up the wrong tree looking at the switch config, I switched over to clearpass and located my problem. Embarassibngly the device I added had to clearpass the wrong IP address assigned to it. Once I fixed that it worked. Thanks 802.zak!
    TS
