Wired
Aruba 8320 IP-SLA and Route changing
  • 1.  Aruba 8320 IP-SLA and Route changing
    Posted Feb 21, 2023 11:00 AM
    Hello, i've got an 8320 where i would like to change the default 0.0.0.0/0 route depending on the ip-sla result, just like tracking in cisco, is there any way to do this in this switch without third party apps?
  • 2.  RE: Aruba 8320 IP-SLA and Route changing
    Posted Feb 21, 2023 11:11 AM
    There is much more powerful mechanism in AOS-CX called NAE. This thread contains an example similar to your query - https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=30466
    Ivan Bondar
  • 3.  RE: Aruba 8320 IP-SLA and Route changing
    Posted Feb 22, 2023 11:58 AM
    This worked beautifully, thank you very much!
  • 4.  RE: Aruba 8320 IP-SLA and Route changing
    Posted Jun 11, 2024 06:39 PM
    Is this possible to do with Aruba 6405 switch series?
    I don't see the ability to install that script on those model, as was demonstrated in the document.
    Thank you,
    Alex
  • 5.  RE: Aruba 8320 IP-SLA and Route changing
    Posted 29 days ago
    It should be possible to do this with a 6405 switch. They support NAE.
  • 6.  RE: Aruba 8320 IP-SLA and Route changing
    Posted 28 days ago
    Thanks for getting back to me.
    Unfortunately the 'Connectivity Monitor' script does not exist within the ASE list on the 6405.
  • 7.  RE: Aruba 8320 IP-SLA and Route changing
    Posted 27 days ago
    Yeah,  it doesn't say 64xx is supported on the script but since it's AOS-CX the script might still work on 64xx switches. I think you should give it a try.  Because i made it work on a virtual CX switch.
