It looks like that some official Aruba 8325 info (product web page, Datasheet and QuickSpecs) were finally published!
yes, this is in addition, not as replacement.
Also, thanks for the feedback, quick specs do not make reference to VSX, but it should. DataSheet does appropriately.
VSX is fully supported on 8325 as well.
If I look into the datasheet I can't find any 25G transeiver supported for the 8325-48Y8C? Does it support only SFP/SFP+ at the moment?
The Aruba 8325's QuickSpecs reports those SFP28 Transceivers as supported on Aruba 8325-48Y8C 48p 25G SFP/+/28 8p 100G QSFP+/28 (Max 48):
