Wired Intelligent Edge
Aruba 8400 - Community 'public' can't be deleted
This thread has been viewed 31 times
  • 1.  Aruba 8400 - Community 'public' can't be deleted
    Posted Dec 30, 2021 01:19 PM
    Hello all,
    I tried to delete public snmp community but it did not work.
    I saw this post but it does not anwer to my issue.
    Airheads Community
    Airheads Community remove preview
    Airheads Community
    Hidden page that shows all messages in a thread
    View this on Airheads Community >
    So when I tried to delete, I have the same error :
    Aruba-8400(config)# no snmp-server community public
    Community 'public' can't be deleted, as it is linked with another configuration.
    I saw in "AOS-CX 10.07 SNMP/MIB Guide" that when we create a private snmp community, it deletes public snmp communicty. So I tried (my 8400 is in 10.07 version) :
    Aruba-8400# sh run | i snmp
    snmp-server community myprivateSNMP
    Aruba-8400(config)# no snmp-server community myprivateSNMP
    Aruba-8400(config)# snmp-server community myprivateSNMP
    Aruba-8400(config-community)# end
    But it does not work.
    In the post I linked, the best answer tells to delete snmpv3-context. But i have no snmpv3-context.
    Can someone help me ?
    Thank you in advance.
    Matthew
    Matthieu Geffroy
  • 2.  RE: Aruba 8400 - Community 'public' can't be deleted
    Posted Jan 04, 2022 12:56 PM
    Matthew, which CX version are you running on your 8400?
    Charlie Clemmer
  • 3.  RE: Aruba 8400 - Community 'public' can't be deleted
    MVP GURU
    Posted Jan 05, 2022 02:44 AM
    if you try to remove the public after create your own community ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 4.  RE: Aruba 8400 - Community 'public' can't be deleted
    Posted Jan 05, 2022 04:47 AM
    yes, first create additional community, then remove public one.
    Vincent Giles
  • 5.  RE: Aruba 8400 - Community 'public' can't be deleted
    Posted Jan 11, 2022 06:55 AM
    Hello all and best wishes for the new year,
    Sorry for the delay, but I was out of office.
    My CX version is 10.07.
    Here what I tried :
    So it seems not working.
    Thank you for your answers and your help.
    Best regards,
    Matthew
    Matthieu Geffroy
  • 6.  RE: Aruba 8400 - Community 'public' can't be deleted
    Posted Jan 11, 2022 11:06 AM
    Matthew,
    Do you have any snmp traps configured that are still using public?
    I just tested the same in my lab with 10.07 with no problem. I can for can force the error you listed when trying to delete a community that is referenced by a trap destination.
  • 7.  RE: Aruba 8400 - Community 'public' can't be deleted
    Posted Jan 12, 2022 02:48 AM
    Hello cclemmer,
    This is it !
    I deleted this command :
    snmp-server host x.x.x.x trap version v2c
    Then I could delete community public !
    Thank you very much for your help.
    Have a good day.
    Best regards,
    Matthew
    Matthieu Geffroy
