Wired Intelligent Edge
Aruba 8900 user manual
  • 1.  Aruba 8900 user manual
    Posted Aug 23, 2019 03:38 AM
    Dear Aruba Support
    Can I have Aruba Core Switch XL.10.03.0030 user manual.
  • 2.  RE: Aruba 8900 user manual
    Posted Aug 23, 2019 05:00 AM
    All the user manual and release notes are on :
    https://asp.arubanetworks.com
    or here as well (ex 8400):
    http://h17007.www1.hpe.com/us/en/networking/library/index.aspx?cat=switches&subcat=8400&type=4+6+7+13#.XV-qrOgzZjG
    Most information for 10.3 is there.
    If you talk about Release Notes for 10.03.0030, then this should be available when the release is on ASP (shortly).
  • 3.  RE: Aruba 8900 user manual
    MVP GURU
    Posted Aug 23, 2019 05:39 AM
    You need what ? release note ? or doc
    For doc it is available here http://h22208.www2.hpe.com/eginfolib/Aruba/OS-CX_10.03/5200-5942/index.html#book.html it is for 10.03.xxx
  • 4.  RE: Aruba 8900 user manual
    Posted Sep 03, 2019 05:23 PM
    Aruba 8900?.
    I think you are referring to Aruba 8400, if so, the information you need is here:
    https://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-a00068057en_us-1.pdf
    Regards
