Aruba 9000 OSPF Capabilities
  • 1.  Aruba 9000 OSPF Capabilities
    Posted Apr 05, 2020 12:31 PM
    Is the Aruba 9000 series in controller mode capable to run OSPF ?
    * the 9000 not mentioned in the user guide, in case it capable to run ospf
    please advice if it there any limitations like:
    - areas
    - route records
    - load sharing traffic across multi routes with the same cost .
  • 2.  RE: Aruba 9000 OSPF Capabilities
    Posted Apr 05, 2020 01:32 PM
    Hi.
    Yes. 9004 controllers support OSPF.
    There is no documented maximum OSPF numbers for this model yet, but I would consider the numbers described for the 7005/7008 models.
  • 3.  RE: Aruba 9000 OSPF Capabilities
    Posted Apr 05, 2020 01:43 PM
    Hi
    Thank you for the quick response .
    just checking is that supported in the Controller Mode ?
    and do you know if it capable to preform load sharing across few routes in this in this mode ?
  • 4.  RE: Aruba 9000 OSPF Capabilities
    Posted Apr 05, 2020 02:29 PM
    Yes. It will work on controller mode.
    I haven't found documentation yet with numbers to know about the maximum number of paths, but I am certain that OSPF ECMP will  allow you to load balance the traffic across same cost links.
