Aruba 9000 VPN Capabilities
  • 1.  Aruba 9000 VPN Capabilities
    Posted Aug 10, 2020 03:03 AM
    I'm tring to figure out if the 9000 in Controller mode supporting site2site vpn, this capability is mentioned in the 7000 datasheet but not in the 9000's.
    also in the arubaos datasheet there in no exclusion for the vpn capabilities for the 9000 series..
  • 2.  RE: Aruba 9000 VPN Capabilities
    MVP EXPERT
    Posted Aug 10, 2020 03:13 AM
    The 9000 will support SSL/IPSEC VPNs. This is noted in the datasheet by the concurrent SSL/IPSEC session support.
  • 3.  RE: Aruba 9000 VPN Capabilities
    Posted Aug 10, 2020 05:40 AM
    Hi Craig,
    "concurrent SSL/IPSEC session" can point on VIA and RAP sessions it is not promising that the Site2Site will be supported.
    do you have more specific information regarding the 9000 ?
