Wireless
Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
This thread has been viewed 26 times
  • 1.  Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
    Posted Dec 21, 2022 11:53 AM
    Does the new Aruba 9240 Gateway/Controller support 1G copper SFP transceiver (J8177D)? I cant find a documentation anywhere to confirm.
  • 2.  RE: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
    MVP GURU
    Posted Dec 22, 2022 06:22 AM
    Have a look at the Aruba 9200 Series Campus Gateways Ordering Guide, apparently the SKU J8177D is not a supported option.
  • 3.  RE: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
    Posted Dec 22, 2022 09:46 PM
    A colleague just found this slide in a presentation. Apparently it is listed below as one of the tested and validated Transceivers. Can anyone validate?
  • 4.  RE: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
    MVP GURU
    Posted Dec 23, 2022 11:40 AM
    That's the reason why I used the word "apparently"...
