Aruba AC650 TPM error
  • 1.  Aruba AC650 TPM error
    Posted Jul 05, 2018 09:26 AM
    ArubaOS Version 6.4.4.16 (build 61809 / label #61809)
    Built by p4build@lemnos on 2017-10-06 at 23:30:21 PDT (gcc version 3.4.3)
    Copyright (c) 2002-2017, Aruba Networks, an HP company.
    <<<<< Welcome to Aruba Networks - Aruba A651-US-1 >>>>>
    Checking Inventory...OK
    Starting watchdog processes
    No of processor 3
    Check/update Boot Image
    gunzip: bad block type 3
    gunzip failed on /tmp/collected-tpm.data.gz; error=256Bad magic number in header, secondary bank
    Both primary and secondary compressed certificates are bad or missing
    Reboot Cause: Power Failure.
    SKIPPING Generating SSH Keys......0022
    done.
    Initializing TPM and Certificates
    mount: Mounting /flash/img0/mswitch/sap/ on /mswitch/sap/images failed: No such file or directory
    Ancillary files are not present
    Restoring the database...done.
    find: /flash/img0/mswitch/webui: No such file or directory
    BusyBox v1.01 (2017.10.07-06:23+0000) multi-call binary
    Usage: touch [-c] FILE [FILE ...]
    Update the last-modified date on the given FILE[s].
    Options:
    -c Do not create any files
    Starting hwMon
    Error Mounting /mnt/img1
  • 2.  RE: Aruba AC650 TPM error
    Posted Jul 05, 2018 09:33 AM
    Aruba Networks
    No of processor 3
    Crash information available.
    done.
    Options:
    Starting hwMon
  • 3.  RE: Aruba AC650 TPM error
    Posted Jul 06, 2018 09:11 AM
    Aruba 651 is only supported till ArubaOS 6.2 according to the End-of-Life page. It could be that the controller works till 6.4 but with the internal AP disabled.
    Could it be that the flash has been erased on this unit?
    You could try to format the flash and upload new firmware.
    Unfortunately, the 651 is pretty old and no longer supported.
  • 4.  RE: Aruba AC650 TPM error
    Posted Jul 06, 2018 05:13 PM
    yes,we have formated the nand flash and reinstall the aos, and even we have changed the sop48 nand flash from another work well 650, it is same.
    So we think there are some bad block in another nand flash (BGA one)
    There are two nand flash in 650. one sop48+one bga
  • 5.  RE: Aruba AC650 TPM error
    Posted Jul 10, 2018 02:24 PM
    Sorry, it looks to me that the unit is just broken. I'm out of options to help you.
