What release ?
the switch have an Internet Access ?
it will be better to open a new issue...
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jul 22, 2021 06:30 PM
Subject: aruba activate-aruba CX 6400
Yes, the device registered in AC
License assigned
Ian Salgado
Original Message:
Sent: Jul 22, 2021 08:19 AM
is the device registered in your central account ?
Kamal Takodra
Original Message:
Sent: Jul 22, 2021 07:10 AM
Yes, I do need central
What I was showing was that i have tried disabling it & re-enabling
but the error persist
The switch will not show in aruba central
Ian Salgado
Original Message:
Sent: Jul 22, 2021 06:43 AM
You need central ? or not ?
Original Message:
Sent: Jul 22, 2021 04:55 AM
yep tried that as well
switch(config-aruba-central)# disable
switch(config-aruba-central)# enable
still same issue :-(
Ian Salgado
Original Message:
Sent: Jul 22, 2021 04:27 AM
Do you have try the
switch(config)# aruba-central
Original Message:
Sent: Jul 20, 2021 09:16 PM
is there further resolution on this one ?
I'm having the same issue
I have added a DNS server
I have sync to ntp server
i have added the correct time zone.
but still the same issue
Ian Salgado
Original Message:
Sent: Mar 23, 2020 04:38 PM
switch# show aruba-central
Central admin state : enabled
Central connection status : N/A
Central location : N/A
Activate connection status : connection_failure
Activate Server : devices-v2.arubanetworks.com
System time synchronized from Activate : N/A
VRF for connection : N/A
