Aruba Activate fail-prov-no-rule failure
This thread has been viewed 38 times
  • 1.  Aruba Activate fail-prov-no-rule failure
    Posted Jan 28, 2013 10:16 AM
    I have a remote AP (RAP3) , set up on Aruba Activate with a controller profile, set to convert to remote and assigned an AP-Group.
    Other remotes (RAP3) are up and running on the controller, however a new one fails with this message
    fail-prov-no-rule
    I have factory reset the AP
    It has been trying for 3 days
    What does fail-prov-no-rule mean?
  • 2.  RE: Aruba Activate fail-prov-no-rule failure
    Posted Jan 28, 2013 05:45 PM
    That message means that device is not associated with a folder that contains a provisioning rule.
    Resolution:
    1. Move device into folder with provisioning rule
    2. Create a provisioning rule in the folder that contains this device.
    Send me your user-id or customer info and I can take a look if needed.
    Paul
  • 3.  RE: Aruba Activate fail-prov-no-rule failure
    Posted Jan 28, 2013 08:10 PM
    strange it is in a folder with 3 other devices and a provisioning rule.
    My userid is the same as here:
    turner
