last person joined: 2 hours ago
Aruba Airgroup port definitions
  • 1.  Aruba Airgroup port definitions
    Posted Sep 20, 2019 02:01 PM
    Is there some documentation somewhere that defines what ports are included in the pre-defined Airgroup services within the ArubaOS?
    Currently, I have the following enabled:
    • default-airplay
    • default-dlna-media
    • default-googlecast
    Some of our staff are using an app called "AirParrot 2" to cast with Macbooks.  This app will continually crash, except if the WiFi is turned off on the Macbooks.  I'm trying to see if there is a discrepancy between the ports AirParrot requires, and what is configured in the default services I have enabled.
    Attached is the port requirements for Airparrot.
  • 2.  RE: Aruba Airgroup port definitions
    Posted Sep 20, 2019 02:39 PM
    This may give you an idea.
    https://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/AirGroup/Best_Practices_Limitations.htm
    For exact configuration on your device , check the role the user falls into.
    Show rights "role of the user"
    This should give you a detailed view of allowed and blocked ports.
