Aruba Airwave 8.2.7
  • 1.  Aruba Airwave 8.2.7
    Posted Feb 06, 2019 05:37 AM
    Dear Community,
    I am getting a above error message in Airwave running 8.2.7.
    Unable to understand this messge kindly suggest.
    Thanks & Regards,
    Darshan
  • 2.  RE: Aruba Airwave 8.2.7
    Posted Feb 06, 2019 08:06 AM
    Error states clean_database process(part of nightly maintenance) is failing everyday during the maintenance process.
    This means the historical clean up wouldnt be happening properly everything. One of the reason for this can be cause some of the table might be huge in size and clean database is timing out.
    I would suggest opening a TAC case so that they can take the shell access and check the table which are huge in size and help you with the cleanup.
