Network Management
Aruba Airwave client report - old had 802.11b and n, new one does not.
  • 1.  Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 22, 2016 03:36 PM
    a report of one of my vessels, in december showed 802.11b, 802.11n (2.4GHz & 5GHz), 802.11a, and 802.11g clients.
    most recent report only shows 802.11a, and 802.11g clients
    is there a setting that changes reporting, or possibly turned off my 802,11n and why my ac is not showing up as well?
    setting in controller configuration have high throughput turned on for both n (a & g radios) and ac on the a.
    also not sure why b would no longer have a presence.
    screenshots attached
    thanks in advance
  • 2.  RE: Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 22, 2016 05:20 PM
    It is possible that it was false-reporting 802.11b-only clients before you upgraded.  If you have a known 802.11b client, you should connect it and see how it reports it.
  • 3.  RE: Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 22, 2016 05:37 PM
    agreed, and thank you - I am less worried about the b client showing/not showing, but the n clients i should see on both 2.4 and 5, but am seeing it on neither.
    to see only a or g, seems odd.
  • 4.  RE: Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 23, 2016 05:00 AM
    I see it now.  I would open a TAC case so that they can get the specifics of your installation, and how that report is configured.  That does not look normal.
  • 5.  RE: Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 30, 2016 08:20 AM
    found out a few things.
    all of the settings turning on n, and ac were off. found a few more after i posted, and now they report and connect on the n and ac bands. b is still vacant as expected. but otherwise, all is good. thank you everyone
  • 6.  RE: Aruba Airwave client report - old had 802.11b and n, new one does not.
    Posted Aug 30, 2016 08:41 AM
    Screenshot of the settings, please.
