Network Management
Aruba Airwave - Disable Template audits?
  • 1.  Aruba Airwave - Disable Template audits?
    Posted Apr 20, 2017 03:20 PM
    I enabled template auditing or comparing for one of my groups and now can't seem to find a way to stop doing so.  I want to be able to:
    • Disable template auditing
    • Ignore all possible configuration mismatches
    • Remove the 'mismatched' flag on the controllers in this site
    How can I disable template auditing? I've done the second and third point for our other groups.  I tried to delete the template file that I had used previously, but that didn't seem to help at all.  The audit page still shows the file as if it is still there somewhere.
  • 2.  RE: Aruba Airwave - Disable Template audits?
    Posted Apr 21, 2017 05:12 AM
    Hi Patrick,
    I understand that you want to disalbe audit and ignore mismatch in Airwave.
    • Naivage to AMP Setup > General > Device Configuration Audit Interval set to Never
    • Groups>Basic >Audit Configuration on Devices set  to No
      (Toggling this will set all devices in this group to 'Monitor Only')
    • Go to APs/Devices>Audit page of the controller and click on customize and select all the mismatches and save it to ignore mismatches.
    Pavan
    If my post address your query, give kudos:)
  • 3.  RE: Aruba Airwave - Disable Template audits?
    Posted Apr 21, 2017 03:24 PM
    Hi Pavan,
    I do want to audit configurations, but not right now.  I want to keep the audit configuration option enabled, but disable template auditing.  For example one group sees this on their audit page:
    I don't want it to try to match against a template.  I want it to respect the "ignore mismatch" options other groups have, like this:
    no-templates.PNGHow do I disable the auditing of templates on a group?
  • 4.  RE: Aruba Airwave - Disable Template audits?
    Posted Apr 22, 2017 04:06 AM
    Hi ,
    If you want to disalbe audit for group specific , then disalbe audit in that specific group basic page only
    • Groups>Basic >Audit Configuration on Devices set  to NO
    Pavan
    If my post address your query, give Kudos:)
  • 5.  RE: Aruba Airwave - Disable Template audits?
    Posted Apr 22, 2017 04:15 AM
    After disabling audit in group basic page, if you still see configuraiton status as error, then first import the device templete from Groups> Template page. In audit page, click on Add Template link, it will take you to template page, once template is imported , disable auit option and ignore mismatches.
    Pavan
