Network Management
Aruba AirWave KVM Guest Agent
This thread has been viewed 19 times
  • 1.  Aruba AirWave KVM Guest Agent
    Posted Jan 08, 2024 12:51 PM
    ist there any possibility to install Qemu Guets Agent on AirWave 8.2.15 running on KVM/Proxmox?
    I only found very old instructions saying to interrupt installation setup by pressing ALT+C, but doesn't seem to work anymore.
    Best regards
    Dennis
  • 2.  RE: Aruba AirWave KVM Guest Agent
    Posted Jan 12, 2024 09:00 AM
    AirWave CLI is locked. So, we will not be able to install any 3rd party RPMS. We dont support either.
    Regards
    Gowri Amujuri
  • 3.  RE: Aruba AirWave KVM Guest Agent
    Posted Jan 16, 2024 10:47 AM
    would it be conceivable to implement this in future versions of Airwave, as Airwave 8.3.0 is based on Red Hat Enterprise it should not be a problem.
    Best regards
  • 4.  RE: Aruba AirWave KVM Guest Agent
    Posted May 06, 2024 04:24 PM
    Currently there are no Plans to open shell access to AirWave. Its was removed for security reasons.
    Regards
    Gowri Amujuri
