Aruba Airwave - to check how many time client drop
  • 1.  Aruba Airwave - to check how many time client drop
    Posted Jul 29, 2021 11:57 AM
    Hi Team,
    I just use aruba airwave to generate report for AP device. From the report we can check AP utilization and client status. Can we check how many times client connection drop / disconnect from 1 AP?
    Thank You
  • 2.  RE: Aruba Airwave - to check how many time client drop
    Posted Jul 30, 2021 07:18 PM
    see if using match event report helps.
    it can be used to track matching events that occurred on devices.
  • 3.  RE: Aruba Airwave - to check how many time client drop
    Posted Aug 01, 2021 04:48 AM
    Hi ariyap ,
    Noted, mean from the matching event able to show the device connected to the AP.
    May I know the meaning of the Band Steer and Sticky Client at reasons part?
    NOOR HAFIZI UZAIRI
