Aruba and Forti-Authenticator integration
  • 1.  Aruba and Forti-Authenticator integration
    Posted Nov 20, 2018 07:01 AM
    Dear All,
    Our customer has Aruba 7030 wi-fi controller and Forti-Authenticator.
    They want to authorize wireless client endpoint on Forti-Authenticator (Captive Portal).
    Is it possible?
  • 2.  RE: Aruba and Forti-Authenticator integration
    Posted Nov 24, 2018 04:22 PM
    I din't think so, a better solutin would be to authN the users on CPPM and use the fortiauthenticator integration to share user details/roles with FA as FSSO.
  • 3.  RE: Aruba and Forti-Authenticator integration
    Posted Jan 14, 2020 10:38 AM
    Can you provide steps to implement this? I've added the fortiauthenticator as a radius accounting server, so that those details are sent to the fortiauthenticator. But I am still not seeing the users
  • 4.  RE: Aruba and Forti-Authenticator integration
  • 5.  RE: Aruba and Forti-Authenticator integration
    Posted Nov 24, 2018 10:26 PM
    Yes basically its possible , because Forti-Authenticator is radius server .
    What type of the authentication you are using (customer requirement , 2 factor , Social or user name and password )
    as per my knowledge flow like this ,
    1. on Wifi controller add Forti-authenticator as the radius server
    2.in fortiauthenticator create wifi controller as the radius client
    3.in aruba capative portal config redirect authentication to external server
    please check these links for reference
    https://community.arubanetworks.com/t5/Wireless-Access/External-Captive-Portal-Authentication/td-p/236949
    https://cookbook.fortinet.com/fortiauthenticator-guest-portal-fortiwlc/
  • 6.  RE: Aruba and Forti-Authenticator integration
    Posted Jun 12, 2019 04:51 AM
    Hi Danny Jump:
    May i ask a question.
    If just to use captive portal authetication for my environment not use FSSO, also need use FortiAuthenticator?
    Below is my architecture:
    User Login-->Aruba AP or Aruba SW-->CPPM(RADIUS Accounting)-->FortiGate
    Ref. CPPM TechNote - 3rd Party Enforcement Points (Fortinet) V1.1
    Have a nice day.
