Aruba and Splunk, Log Setup
  • 1.  Aruba and Splunk, Log Setup
    Posted Aug 13, 2014 11:14 AM
    Hi all,
    Can you someone describe the configuration of Splunk to receive logs like security/wireless from Aruba?
    I have the Splunk server address and the security logs set on the "Logging" menu on ArubaOS 5.0.4 and Splunk set to listen on UDP 514.
    I can't see any logs coming from the Aruba controller when I do a search query on Splunk.
    Thanks.
  • 2.  RE: Aruba and Splunk, Log Setup
    Posted Aug 13, 2014 11:16 AM
    Try this:
    (config) #logging <splunk-ip> type security severity informational
  • 3.  RE: Aruba and Splunk, Log Setup
    Posted Aug 13, 2014 12:09 PM
    Thanks, will give that a try and let you know if that works.
    Anything else that needs to be considered?
