Hi All,
I am configuring clustering in aruba AOS 8.2 architecture, So far i have done the config's as prescribed by aruba documentation. the cluster has come up, but when i see the AP details it is not showing the IP of standby controller ...FYI two VMC's are used as controller's. i have attached the screenshot for better understanding...any help wolud be appriciated.
remember I had some issues with this running 8.0.1 i lab on VmWare. I haven't got the VmWare server access here - but something like promiscius mode (or similar) on VmWare networking had to be enbaled to get cluster up-and-running
Hi Jakob_di
Even after enabling the promiscues mode, i was facing this problem..
FYI, Promiscius mode is enabled in the VM network.
You also have to enable forged transmits. Have you seen the document here? https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28637
Hi Guys
The issue is resolved now, We installed the aruba AOS 8.2 in the 7024 hardwares and the clustering started working fine.
i guess there was some misconfiguration in our VM's, cjoseph and #6938 thanks for help.
Yes sir. :-)
