aruba AP 105 access point deployment
  • 1.  aruba AP 105 access point deployment
    Posted Sep 15, 2020 11:12 PM
    I am new in aruba AP so Don't have any idea about ap 105s
    I have read here that we can't configure ap 105s without controller
    So i want to know that if i configure ap 105s with controller after that can it work with simple poe switch
    Means i already configure ap 105 from controller like ssid ip address eventhing then i pull out from controller and insert some poe switch wire will it work with that switch with just lan cable with poe.
  • 2.  RE: aruba AP 105 access point deployment
    Posted Sep 15, 2020 11:17 PM
    If the model number on the sticker is an IAP-105 (an Instant AP), you can configure it without a controller.  If the model number says AP-105, it requires a separate hardware controller.
  • 3.  RE: aruba AP 105 access point deployment
    Posted Sep 16, 2020 02:40 AM
    I Know for configuration i need controller
    I am asking after configuration done and saved like ssid name ip address etc. Then can i used it with any poe switch just inserting wire from poe switch
  • 4.  RE: aruba AP 105 access point deployment
    Posted Sep 16, 2020 04:08 AM
    You will need a controller during the operation. It's not that the controller will push configuration, the AP will need the controller all the time.
