Aruba AP 105 keep rebooting
  • 1.  Aruba AP 105 keep rebooting
    Posted Oct 23, 2014 01:04 PM
    HI,
    i'm trying to work with Aruba AP 105 model.
    i've connected it to the Aruba controller, using these commands:
    pboot> purgeenv
    Un-Protected 1 sectors
    .done
    Erased 1 sectors
    Writing
    apboot> set master <controller-ip>
    apboot> set serverip <controller-ip>
    apboot> set bootcmd tftpboot
    apboot> save
    Saving Environment to Flash...
    apboot> boot
    but after that the AP can't come up - it's in a loop of reboots and the console output is:
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 192.165.100.254
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.165.100.10
    DHCP DNS server: 0.0.0.0
    DHCP DNS domain:
    Controller address: 192.165.100.3
    Using eth0 device
    TFTP from server 192.165.100.3; our IP address is 192.165.100.254
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
    Retry count exceeded; starting again
    DHCP broadcast 1
    DHCP DNS domain:
    Using eth0 device
    DHCP broadcast 1
    DHCP DNS domain:
    Using eth0 device
    Loading: T T T T T
    any idea what went wrong?
    just a note: i've managed once to add it to the controller using the above commands.
    (the controller showed the AP in the AP list)
    but when i changed the AP name (in the controller under Configuration -> AP Installation) the AP got stuck in the reboot loop..
    when i retried to attach the AP to the controller i got again the reboot loop..
    thanks for any help :)
  • 2.  RE: Aruba AP 105 keep rebooting
  • 3.  RE: Aruba AP 105 keep rebooting
    Posted Oct 26, 2014 06:13 AM
    thanks!it works now.
    but i still have some reboots from time to time withe this reason:
    Reboot requested by controller shutting down watchdog process (many will restart it)
    how can i disable it? so i won't have these reboots all the time?
    thanks!
