Aruba AP 105s failing to communicate with the controller
  • 1.  Aruba AP 105s failing to communicate with the controller
    Posted Apr 17, 2015 11:04 AM
    2 Aruba 105s are unable to reach the controller anymore (ArubaOS Version 6.3.1.13).
    Both power and ethernet lights are green, radio lights not coming on - the Power led is blinking red after a few minutes due to rebooting. It has been working for just under a year but suddenly failing for both APs. Using it on POE, and verfified that the switch is working. Tested both APs in another building and both work fine.They have been disconnected from the ethernet port and reconnected but still unable to reach the controller, any ideas?
    Thanks...
  • 2.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 17, 2015 11:08 AM
    You really need to get a console cable connected to them to see the messages on bootup. You can also escape out of the boot process immediately and run the dhcp command to make sure it is getting a proper IP address.
  • 3.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 17, 2015 11:11 AM
    Thanks Zach i'll look into that...
  • 4.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 17, 2015 11:15 AM
    On the controller side of things run the following command and it may show what's going on :
    show log system 100
  • 5.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 17, 2015 11:55 AM
    Pull network cable out of one of the APs and plug it into your laptop. Do you get an IP address? Is it in the correct VLAN?
    Cheers
    James
  • 6.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 20, 2015 11:46 AM
    Problem resolved, there was an issue with one of the switches that indirectly connects which lost connectivity via snmp. Fixed via a cold restart
  • 7.  RE: Aruba AP 105s failing to communicate with the controller
    Posted Apr 28, 2015 11:11 AM
    It was a neighbouring switch device which was not sending snmp traffic...It was restarted which resolved the issue
