Aruba AP-125 - setup.
  • 1.  Aruba AP-125 - setup.
    Posted Jun 19, 2014 06:26 PM
    Hi Guys,
    I'm new here. I've got 4 Aruba AP-125, but I don't have a controller. Is there a way to run them without controller as a regular APs? If not, can you advise which (prefarably used and cheap one) controller should I buy? I don't wanna throw APs away or waste much money for the controller. I just thought that I can run and PoE them in simple home network to cover by WiFi range whole big house.
    Thanks!
    Jan
  • 2.  RE: Aruba AP-125 - setup.
    Posted Jun 19, 2014 06:33 PM
    You definitely need a controller with those access points...
  • 3.  RE: Aruba AP-125 - setup.
    Posted Jun 19, 2014 06:44 PM
    Check ebay for "Aruba Controller" And 800 would work with the 125s but not run newer codes. Cheapest option.  IT would be all you need for a home lab unless you are trying to learn some of the newer features.
  • 4.  RE: Aruba AP-125 - setup.
  • 5.  RE: Aruba AP-125 - setup.
    Posted Jun 19, 2014 09:10 PM
    The 6x0 series is nice because it's fairly small and quiet.
  • 6.  RE: Aruba AP-125 - setup.
    Posted Jun 20, 2014 02:11 AM
    I would definitely keep an eye out for 6x0 controllers as people will be starting the move to the 7010 controllers now that they've been released.
  • 7.  RE: Aruba AP-125 - setup.
    Posted Jun 05, 2015 02:28 PM
    Newbie here as well.  I'm the new owner of an AP-125... and am now going to get a controller.  Dumb question - does that AP need to hang directly off the controller?  Or, can a switch or two sit between the AP and the controller?
    I have a PoE injector that is supposed to be compatible, that of course I'll wire directly to the AP.  My thinking is that if I get a big and/or noisy controller - I'd love to be able to put that in the basement where I'm less concerned about space constraints and/or noise.
    thx!
  • 8.  RE: Aruba AP-125 - setup.
    Posted Jun 05, 2015 02:30 PM
    It can be connected with a switch, yes.
