Aruba AP-135 - how to configure
  • 1.  Aruba AP-135 - how to configure
    Posted Nov 23, 2016 09:29 AM
    I just received 2 Aruba AP-135 used devices. I want to use those for home use, to have wifi on my 2 floors. I wanted to put one AP on every floor.
    I received the APs yesterday and connected both to the network after restoring them to factory settings. Power led and ENET0 began to blink and didn't stop.
    It seems that I can't connect directly to the AP to make the necesary settings.
    After reseaching, it seems that there are 2 types of Aruba AP-135: one instant, that can be configured directly by web interface, and another type that can be configured using a controller.
    In this case what can I do? Is there any chance to be able to setup the 2 APs for inhouse using? I do not want to buy a controller. Is there a software controller that I could use to make the setup?
    I can't find any informations about this topic.
    Thank you!
  • 2.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 09:30 AM
    AP-135s can only be used with a controller.  It cannot be used as a standalone AP.
  • 3.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 09:31 AM
    You would need to acquire a controller or switch them out for IAPs.
  • 4.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 09:36 AM
    Hmm, that sux.
    And which is the cheapest controller on the market? If I setup the APs using a controller, can I remove the controller from the network? Or I have to have it constantly in the network?
    Thank you!
  • 5.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 09:37 AM
    The controller needs to be there constantly for an AP-135 to work.
  • 6.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 11:32 AM
    Ok. Could you, pleasw, recommend me the cheapest controller? Maybe I will find a second hand one, so that I will be able to use the APs.
    Thank you!
  • 7.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 03:32 PM
    I found on ebay 2 low-cost Aruba controllers. First is this one: Aruba Networks 800 LAN Wireless Mobility Controller 8-Ports Model: 800-US.
    Second is this one: Aruba Networks 2400 Mobility Controller
    Could you, please, tell me if it's ok for what I need?
    The initial setup of the controller and the APs has to be made by someone with experience in the networking area? Or I will be able to do it myself? How complicated it is? I am a programmer, but have no experience in networking.
    Thank you!
  • 8.  RE: Aruba AP-135 - how to configure
    Posted Nov 23, 2016 04:28 PM
    Those are very old and won't run anything past AOS 5.0 (we are now starting 8.0). I would avoid as there's little to nothing to setup that would be relevant in the modern OS/cofnig pages now.
  • 9.  RE: Aruba AP-135 - how to configure
    Posted Nov 25, 2016 04:12 PM
    A 620 or 650 Will do
  • 10.  RE: Aruba AP-135 - how to configure
    Posted Nov 25, 2016 04:13 PM
    But you are limited to 6.4.x versions. They provide PoE as well
