Aruba AP 215 in remote AP operating mode
  • 1.  Aruba AP 215 in remote AP operating mode
    Posted Sep 08, 2014 04:33 AM
    Hi guy,
    can i use an ap-215 in RAP operating mode?
    I need to cover a remote office, i have some AP-215 for eventually faulty of other.
    So i need to know if i can use it in RAP mode.
    It is possible??|
    thanks in advance
    best regards
  • 2.  RE: Aruba AP 215 in remote AP operating mode
    Posted Sep 08, 2014 05:01 AM
    there is no datasheet on the Homepage, its only listed in the Access Point Matrix.. But normally most of the Campus Access Point (CAP) can run as a Remote Access Point (RAP) too. The Instant Access Point (IAP) can do evertyhing, IAP, CAP and RAP. I can't imagine that Aruba Networks would change something there with the new AP-21X Series. Maybe some smaller Access Points doesn't support the RAP-Mode.
    Thomas
  • 3.  RE: Aruba AP 215 in remote AP operating mode
    Posted Sep 08, 2014 08:13 AM
    Yes - It's supported
  • 4.  RE: Aruba AP 215 in remote AP operating mode
    Posted Sep 08, 2014 08:17 AM
    i have found the datasheet of 210 series.
    http://www.arubanetworks.com/products/access-points/210-series/
    and i have found :
    "CONTROLLER-MANAGED AP OR REMOTE AP (RAP) RUNNING ARUBAOS™
    When managed by Aruba Mobility Controllers, 210 series APs offer centralized configuration, data encryption, policy enforcement and network services as well as distributed and centralized traffic forwarding. Please refer to the Aruba Mobility Controller data sheets for more details".
    So is supported.
    Anyway Thanks
