Aruba AP 225 Config Without Access
  • 1.  Aruba AP 225 Config Without Access
    Posted Mar 21, 2017 12:11 PM
    I took over as sys admin at my company. The previous admin failed to log any passwords as well as backup the configs to the aps.
    Ive tried to recover the password but they are too new in firmware. I got on the phone with hp/aruba and they remoted in and tried everything to reset the password as well.
    So heres my question. Is there a way to backup the config on the controllerwithout having a login?
    Otherwise Im going to have to wipe and reset this master. The problem with this tho is it also is the master for 2 other locations with 20 aps as well. I was able to get into those aps however and backup the configs on those sites.
  • 2.  RE: Aruba AP 225 Config Without Access
    Posted Mar 22, 2017 01:31 PM
    Is this controller or IAP?
  • 3.  RE: Aruba AP 225 Config Without Access
    Posted Mar 22, 2017 02:29 PM
    you need to log in the controller to backup.
    Anyways if you need to do a password recovery on the controlller which is a physical controller
    http://community.arubanetworks.com/t5/Wireless-Access/Aruba-Controller-Password-Reset-Jan06-Tutorial/td-p/130597
    If you got a cluster instant
    As far i know the recovery process was disabled for some reason...
    and you need to whipe out the config...
    I remenber i read about that.. and i found that thread here
    https://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/password-recovery-in-iap-205/m-p/249586
    Cheers
    Carlos
