HI all,
How to factory reset AP 305 using console? There is no RJ45 console port at behind of the AP.
thanks
KL
You do a factory reset with the reset button.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/23249/Default.aspx
Or use the console port. For this AP model you'll need an adapter cable: AP-CBL-SER (JW071A).
what is the duration for pressing the rest button?
Press the button in a hold then power cycle. You'll see the lights flash rapidly a few times. If you have a console connected you'll see a message along the lines of 'reset button pressed'.
